| ..| Gonzo
Stored .stl & .gcode path's
Hello in previous version simply store two path's, where you open .stl and where you save gcode.. new version store only one path and this really annoying, because i use two separate path for this file type's. and i think not only me :)
Re: Stored .stl & .gcode path's
You can change this option in the preferences. Go to Tools > Options, and edit the "File selection behavior" setting. I think you want "remember a unique last used directory for each separate file type".
| ..| Gonzo
yep, sounds right) thank you
