CD92
Part of Model behaves strange by slicing
Hello Support,
I found some strange behavior with the newly purchased Version 5 (5.0.2).
Slicing this model with Version 4 work multiple time without any problems.
With Version 5 depending on the angel (Z-Rotation) sometimes parts are missing, sometimes there are parts added and also some times there is strange artefacting.
You can see it in the picture I attached.
Top left STL Model.
Top right should look like this.
The rest... very strange.
I found out I have to rotate the object about 6° to get the correct slicing.
I hope you can fix this problem, if needet I can provide further information.
Thanks and have a nice day,
Christian
Slicing Problems
Slicing Problems
Re: Part of Model behaves strange by slicing
Can you post the STL file or factory file?
CD92
Hello Jason,
sure, I uploaded the STL and the factory File in the Attachements.
I hope this helps you.
Have a nice day,
Christian
Innen_3.2.factory
(21.46 KiB) Downloaded 154 times
Innen_3.2.stl
(71.18 KiB) Downloaded 133 times
On my screen, it looked like the hole in the top actually protruded through the surface slightly. What happens if you make the hold slightly smaller in the CAD program and then re-export the STL?
