When I make parts, I have to remove the support from the small holes while keeping support in big areas. Is there a way to tell Auto Support to not put support when there is a short span/bridge?
I make a lot of parts with pinholes that dowel pins go into so I can secure the two parts together. The pinholes are about .125" in diameter and the printer has no problem with no support on these holes but getting support out of these smaller holes is difficult.
With my work it is okay to extremely difficulty to manually drill or pull the support out of the small holes, but a "do not auto support on spans shorter than 1mm" would be a setting I would like.
