dmc456
Support extruding to the top of part
How do you keep the supports from passing through the part? See attachment.
fatboy1271
Contact: Twitter YouTube
Re: Support extruding to the top of part
Why is there no response to this? It's still happening in v5.0.2
Creality CR-10S with E3D V6
CR-10 Ultimate Leveling Knob Attachment by Valstrath
Bowden Tube Clip by walter
CR-10 Heavy Duty customisable modular e3D V6 mount Volcano 5015 ABL by chito
#Let'sGoPens!
bolsoncerrado
So many things "still happening" or gone worse on v5.xx :(
jfkansas
dmc456 wrote: ↑Tue Aug 03, 2021 4:11 pm How do you keep the supports from passing through the part? See attachment.
My bet is you have support expansion distance turned on and it isn't needed. Post the model or the factory file.
gearsawe
or use smaller support grid. 4mm never works for me. use the 1mm.
another hack I have found is scale to 200% add 1mm supports then scale down to 50%
the support will scale with the model! think this is a bug. then the support are 0.5mm
