gearsawe
Reload Modified Model - in or above bed issue - Bug?
This may not be a bug depends on how you look at it. I do like the "Reload Modified Model" but need to be careful. If the size changes it may be push down thru the bed basically cutting your model short. Had this bite me in the butt. did not see there was a half mm poking below the bed therefore made a bad print.
Maybe a drop to option after a model reload?
