adamss35
Simplify3d v5 and Astrobox
I purchased upgrade however I cannot connect to my creatorpro printer which is using Astrobox 0.21(3). It appears the Atrobox uses login/username to access the printer page so S3D fails test. Can we have an option to input username/password?
Included is the log file for the fail however I changed my username to "loginusername" where the username would be typed it etc.
Attempting connection at 192.168.2.49:80...
Connection failed.
READ: HTTP/1.0 400 Bad request
READ: Cache-Control: no-cache
READ: Connection: close
READ: Content-Type: text/html
READ: <html><body><h1>400 Bad request</h1>
READ: Your browser sent an invalid request.
READ: </body></html>
SENT: M602
SENT: POST http://192.168.2.49:80/command {"GETPRINTERSTATUS": ""}
READ: <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
<title>404 Not Found</title>
<h1>Not Found</h1>
<p>The requested URL was not found on the server. If you entered the URL manually please check your spelling and try again.</p>
<h1>Not Found</h1>
SENT: GET http://192.168.2.49:80/api/v1/system
<h1>Not Found</h1>
<h1>Not Found</h1>
<h1>Not Found</h1>
SENT: GET http://192.168.2.49:80/login/
<h1>Not Found</h1>
READ: <!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-status-bar-style" content="transparent">
<meta name="viewport" content="width=device-width, initial-scale=1.0, user-scalable=no">
<title> astrobox-3055 - AstroBox</title>
<link rel="stylesheet" type="text/css" href="/static/css/gen/locked.css?21944924" />
</head>
<body>
<div class="row" id="locked-view">
<div class="small-12 medium-10 large-6 columns small-centered">
<div class="locked-area">
<center><img src="/img/astrolock.png"/></center>
<div class="password-container">
<h2 class="bold"><span class="highlight">astrobox-3055</span> is password protected.</h2>
User: <span class="highlight">loginusername</span><br/>
Enter your password for access:
<form id="login-form">
<input type="hidden" name="user" value="loginusername"/>
<input type="hidden" name="remember" value="true"/>
<input type="password" name="pass" class="radius"/>
<div class="loading-button expand">
<button class="button radius success"><b>Enter</b></button>
<span class="button radius disabled success loading bold"><i class="icon-rocket-spinner animate-spin"></i> Sending...</span>
</div>
</form>
</div>
</div>
</div>
</div>
<script type="text/javascript">
var UI_API_KEY = "CD634C6BAB024DEE88BD427B1548D42A";
var HAS_PIN = false;
</script>
<script type="text/javascript" src="/static/js/gen/locked.js?ee078487"></script>
</body>
</html>
READ: <html lang="en">
READ: <head>
READ: <meta charset="utf-8">
READ: <meta name="apple-mobile-web-app-capable" content="yes">
READ: <meta name="apple-mobile-web-app-status-bar-style" content="transparent">
READ: <meta name="viewport" content="width=device-width, initial-scale=1.0, user-scalable=no">
READ: <title> astrobox-3055 - AstroBox</title>
READ: <link rel="stylesheet" type="text/css" href="/static/css/gen/locked.css?21944924" />
READ: </head>
READ: <body>
READ: <div class="row" id="locked-view">
READ: <div class="small-12 medium-10 large-6 columns small-centered">
READ: <div class="locked-area">
READ: <center><img src="/img/astrolock.png"/></center>
READ: <div class="password-container">
READ: <h2 class="bold"><span class="highlight">astrobox-3055</span> is password protected.</h2>
READ: User: <span class="highlight">loginusername</span><br/>
READ: Enter your password for access:
READ: <form id="login-form">
READ: <input type="hidden" name="user" value="loginusername"/>
READ: <input type="hidden" name="remember" value="true"/>
READ: <input type="password" name="pass" class="radius"/>
READ: <div class="loading-button expand">
READ: <button class="button radius success"><b>Enter</b></button>
READ: <span class="button radius disabled success loading bold"><i class="icon-rocket-spinner animate-spin"></i> Sending...</span>
READ: </div>
READ: </form>
READ: </div>
READ: </div>
READ: </div>
READ: </div>
READ: <script type="text/javascript">
READ: var UI_API_KEY = "CD634C6BAB024DEE88BD427B1548D42A";
READ: var HAS_PIN = false;
READ: </script>
READ: <script type="text/javascript" src="/static/js/gen/locked.js?ee078487"></script>
READ: </body>
READ: </html>
READ: <head>
READ: </head>
READ: <body>
READ: </div>
READ: </form>
READ: </div>
READ: </div>
READ: </div>
READ: </div>
READ: </script>
READ: </body>
READ: </html>
Connection failed.
Attempting connection at ws://192.168.2.49:80/websocket...
Connection refused. Make sure the device is turned on and the connection details are correct.
adamss35
Re: Simplify3d v5 and Astrobox
Astrobox 0.21(3) if that helps OR if you can get it working with OctiPI, I can switch.
Shawn
I do not believe Astroprint is currently supported. However, you said you have an OctoPi and I know OctoPrint on a Raspberry Pi is already fully integrated. We use many of those in our office as well. I would recommend trying that instead if you have one.
adamss35
Thanks for the quick reply. I have extra pis so i could make a octopi and probably will. Thanks
