bolsoncerrado
Bring Back the Drop to Table key shortcut (MacOS) Cmd+T
Bring Back the DROP TO TABLE Key shortcut (MacOS) CMD+T!!!!
Re: Bring Back the Drop to Table key shortcut (MacOS) Cmd+T
You can set custom shortcuts for any of the operations in S3D by going to Tools > Keyboard Shortcuts. Just search for "Place surface on bed" and then click Edit Shortcut at the bottom to choose Cmd+T.
bolsoncerrado
This is a weird one: The menus show the shortcut CMD + T to drop items to table but it won't work when i press the combination anymore. I have to manually select the option in the menu :????
I just tested it again and it was working fine on my machine. Using Ctrl+T after editing the shortcut dropped the model as expected.
Was it working for you previously? Or did it never work to begin with? Are you able to edit other shortcuts with other key combinations?
