<axis id="x" length="230" maxfeedrate="18000" homingfeedrate="2500" stepspermm="92.36" endstops="max"/> <!-- Pulley dia: 10.82mm / 1/8 step = 1/(10.82 * pi / 1600) -->
<axis id="y" length="150" maxfeedrate="18000" homingfeedrate="2500" stepspermm="92.36" endstops="max"/> <!-- Pulley dia: 10.82mm / 1/8 step = 1/(10.82 * pi / 1600) -->
<axis id="z" length="165" maxfeedrate="600" homingfeedrate="600" stepspermm="1600" endstops="min"/> <!-- Actual length is 157mm, we reserve ~5mm for safety. TR-8x8 Z axis = 1/(8/1600) -->
<axis id="a" length="100000" maxfeedrate="1600" stepspermm="100" endstops="none"/> <!-- stepspermm is incoming filament length, see comment at bottom for explanation -->
<axis id="b" length="100000" maxfeedrate="1600" stepspermm="100" endstops="none"/>
"X" : { "platform_length" : 230, "max_feedrate" : 12450, "steps_per_mm" : 92.5},
"Y" : { "platform_length" : 140, "max_feedrate" : 12450, "steps_per_mm" : 92.5},
"Z" : { "platform_length" : 165, "max_feedrate" : 800, "steps_per_mm" : 1600},
"A" : { "max_feedrate" : 1600, "steps_per_mm" : -96.275},
"B" : { "max_feedrate" : 1600, "steps_per_mm" : -96.275},
I had exactly the same.acefx wrote:Hardware Mods and repairs
1. Extruder height
Well yes , the first point i noticed was that both extruders were not at the same height ( ?!!? what ?!!?)
Yep , the extruder height as an 0.3mm height offset, be sure to check about this because i wasn't able to calibrate the X & y offset during the inbuild calibration program the left one was squeeching the filament, the right one almost printed in the air. to do that, you must disassemble the print head and check with a caliper the distance between the two head from the base.
[install_dir]\gpx [output_filepath]
[install_dir]/gpx [output_filepath]
Have you tried the zip folder I included above? It's working for my friend who has a Malyan M180acefx wrote:Yesterday , i wrote to s3d support and they gave me that files to, but for now it doesn't work... the extruder doesn't go to the center and doesn't do the wait for heat up and the first "waste" extrude, instead of that it begin to print where it is...
++Added some harware mods
