brockgs wrote:...what printer it's based on...the firmware version it's running...
Hi Brockgs,
I've got the Monoprice Dual Extrusion 3D Printer and I'm very close to buying Simplify3D to use with it. Since I can't get ahold of the software to try it out, I can't be certain that it will work, but here's what I know so far.
From what I've seen and read, ReplicatorG detects it as a Flash Forge Creator X, which I think is kind of a rework of the Makerbot Replicator Dual.
I've gotten the Makerbot Desktop software to work well with it, so far, and it is detected as a Replicator, but it can print with dual extrusion.
I hope this helps a little. If there are options for it, try out the profiles for Makerbot Replicator 1 Dual or the 2X. If that doesn't work, try the profile for the FlashForge Creator Dual.
If you do end up finding settings that work, please do share with us here. I, for one, would love to see Simplify3D support the Monoprice 3DP natively.
Thanks,
Tony
