jack_n
first layer width no effect
Hello,
Changing the first layer width has no effect.
I Tried 100% 125% 150% the part always looks the same on the bottom face.
Re: first layer width no effect
It definately has an effect. I have tried it as well ad it does work. You should be able to see a difference in you gcode preview. Remember that the actual width is determined by you z height calibration on your machine. The tighter the gap the wider the width.
jack_n
Hello,
yes-you are wright.
I did not see this on the part, but in the preview.
Thank you
Joachim
