acefx
Re: Malyan M180 3D Desktop printer ?
Well i've posted the changelog on the main topic.
the 7.8 is stable with better temperature handling, usb print are stable, even doing something else on the PC.
All is functionnal is a good to go.
I will post my setting for Makerware print , i got a pretty good result now.
My next hardware mod will be a more thicker glass bed, because the one in the package is too thin, and so doens't present a good level on the whole surface.
the Z probe need to be shimmed, if not the level spring are too much compressed and bend the heated bed.
Alan
A tip for the Malyan M180 ... Set/adjust the level of the print plate when the maximum plate set temperature is reached.
helmutdz
acefx wrote:I've just contacted malyan and they gave me the lastest firmware ( V7.8) for those who are interested... leave me a PM.
I'm testing it for now, and we will put it online when all the update procedure will be OK
Hello acefx, I am also interest in the new firmaware.
facing you what they have changed.
you can send them to me.
3D Printer in use 3D FreeSculpt EX2 dual head (malyan M180).
acefx
Shared on my google Drive
https://drive.google.com/file/d/0B-5eiE ... sp=sharing
Update procedure for dummies:
make a folder in your C: name "malyan" and put the file in it
Note on what com port the machine is connected (eg com X)
type CMD in your start menu
right click " run as administrator"
Type in the cmd
cd..
cd.. until your are in c:\
the cd malyan
then update.exe -P COMX ( your printer com port) /!\ don't press enter !! /!\
switch off your printer
switch on the printer while pressing the jog dial ( the round button ) and KEEP your finger on it until the process finish flashing.
press enter on the computer keyboard.
Pray !
In 3minutes max it's done. !
Reboot your printer ! and notice the new firmware on it ( 7.8 )
helmutdz
does not work
"update: stk500_recv(): programmer is not responding"
"update stk500_getsync() attempt 1 of 10: not in sync: resp=0x03"
who can read is a clear advantage.
now it is thank you
acefx
The chinese instructions were less clearer than that ;), i spent an hour retrying all the procedure ;))
I just got the mainboard plan here, and there is an external fan port on the main board. a 12v one .
I might be the spare connector stuck on the right interior side of the printer.
I will relaease the upgraded glass clamp & the fan support when i get back from holidays, i'm now in the mountainnnnn !
3d-ua
MakerBot Desktop 3.4.1 R2
http://fano.kiev.ua/Malyan-M180/MakerBo ... .48-r2.zip
Changelog to original:
* autodetect via USB
* excellent online USB print !
* make correct EEPROM map for M180 (Devices->Device Preferences)
* correct machine description (axis length, steps per mm, feedrate, other)
* correct base print profiles for PLA, ABS
* fix tool change unaccelerated speed ! (correct dual color print!)
acefx
Hi 3D UA, I've seen on your repository some upgrade part for filament guide , Good work !
And thanks for the hack !
syl20
I'am a french freesculpt EX-2 owner and i work on Imac, someboby have got the drivers?
3d Freesculpt Ex-2 dual head in action !
acefx
Salut !
The OSX driver are i bit touchy.
See there http://wiki.malyansys.com/wiki.php?id=macosx
Osx Pkg : http://www.malyansys.com/downloads/Maly ... MACOSX.pkg
si tu es Mac OSX 10.10 (Yosemite) need enable developer mode:
Terminal :
sudo chown -R root:wheel usb.kext
sudo chmod -R 755 usb.kext
sudo nvram boot-args="kext-dev-mode=1"
Pour tester que ca fonctionne .
sudo kextutil usb.kext
ensuite telecharge la derniere version de makerware sur le site de makerbot, puis remplace les fichiers avec le patch present dans le recap.
