phil.t wrote:Thanks for giving it a try - I'm glad to hear I'm not the only person seeing this. It has since happened on a couple of my other models.
By the way, here's what that tray looks like printed:
That area of double-infill stands out as a bumpy band in the print, so I'm pretty sure it must be abnormal to be filled like that.
For now, on another model at least, I've turned up the "Allowed Perimeter Overlap" percent under the Thin Wall settings until it stops using infill on the walls and uses additional perimeters (essentially making the wall solid). Note that this seems to be different than picking "Only use Perimeters for thin walls" setting, which for my model created a single perimeter and a empty inside wall space.
Thanks,
Phil
In Phil's picture, you can see that the ribbing only occurs for the layers that have the handle cut-outs. This means that there is less material being printed for these layers, and the speed-overrides are adjusting the speed slowing down these layers. I've found a great way to reduce this, is to either adjust the Speed Overrides so it can only slow my print down to 45% instead of 20% speed, or by disabling that option all-together and lowering my default printing speed under the advanced tab to get rid of the ridging.
-My experience has been that speed is the primary factor for these ridging's.
