Don
Two printers
Is there a way to run two printers on separate prints using two USB connections?
I'm using SD cards now, but I had SD Card Errors twice this week and used the USB to keep things running.
Then it occurred to me, as a backup, I wondered if I could run both printers from one computer.
KeyboardWarrior
Re: Two printers
To do this, you really just need to open two separate windows of the software, and they don't interfere with one-another. I've done this a few times and it works really well.
Don
Re: Two printers
KBW, I'm not quite sure what you mean. I can only have one window open. If I create a new factory, it asks me if I want to save changes to the old one. Unlike Photoshop, for instance, where it does give me a second window.
Maybe I'm approaching it wrong.
BaudR8
Re: Two printers
Don wrote:KBW, I'm not quite sure what you mean. I can only have one window open. If I create a new factory, it asks me if I want to save changes to the old one. Unlike Photoshop, for instance, where it does give me a second window.
Don,
Try double-clicking on the s3d icon to open another window (Windows) to control another printer.
Don
Re: Two printers
I'm a Mac user.
Doesn't work for me.
BUT...
I have both versions (previous and newest) on my machine, and they both seem to be running fine.
I will try to print them at a later time (it's getting late).
I never had any problem with either, so it could work!
TenKOhms
Re: Two printers
Don wrote:I'm a Mac user.
BUT...
I'm a Mac user as well, I usually keep the previous version installed so that I can run multiple instances and connect to multiple printers. Works for me
Umpa
Re: Two printers
Usually for a mac you need to duplicate the app. Rename it slightly and then run the original & the copy. I don't know if S3D will run as it has DRM.
