brockgs
Ignoring Second Print Head - Monoprice 3DP (Flashforge Dual)
I've been getting great prints when printing using the right print head on my Monoprice 3DP (rebranded Flashforge Creator Dual). When I try to print with both print heads though, I can't get it to work. I've selected the Creator Dual profile, set the temperatures on both heads, set the support structure to be the first print head (which is loaded with PVA)...etc. But when I export the file to print, load it on the printer, it only ever warms up the right head and prints those items, no action on the left print head with support.
In the Print Preview window I see it generating the support code, and when I look in the .gcode (although the printer uses the .x3g code to print from SD card) I *seem* to see the settings in there properly for both print heads.
Any suggestions/clues as to how to debug this issue? Thanks.
You can see the supports here.
Screen Shot 2015-01-03 at 8.58.56 PM.png (80.48 KiB) Viewed 2323 times
snippet.gcode
(76.06 KiB) Downloaded 202 times
Re: Ignoring Second Print Head - Monoprice 3DP (Flashforge D
You just need to use the "FlashForge Creator Dual (both extruders)" profile. I'm guessing you are currently using the right extruder only profile, so it will not heat up any extruders besides the right one.
brockgs
That is the profile I'm using. I've attached some screenshots that show 3 of the tabs for the Process that I'm using.
Gcode settings
Gcode settings
Support settings
Support settings
Extruder settings
Extruder settings
TenKOhms
try changing the tool head index on the left extruder to tool 1 instead of 0
