I use the licensed software ver 5.1 for some time . I had to replace the printer Prusa MK3 controller board because one of the motor driver stop working.
After i replaced the board and run the printer setup I try to connect it to the S3D software .From the Machine Control Panel I connect to one of the USB port of pc ( 115,200 no flow control ) and the test pass but when i click the "Cpnnect" button i got a message
"Device not found. Make sure the device is turned on and connected."
Try to reset the pc and the printer with no change
On the PC device Manger porta see the printer connected to usb
I connect the printer to FronterFace I can connect to printer and control movements
Any help ?
Regards ahead Doron
