Image_Engine
Why is bridging not being applied?
I have applied zone to part with obvious overhangs?
EDIT: Working with more than a couple of zones/processes is tough going, it really needs a hierarchy with graphic display of what is mapped where. It cant be this hard...sometimes it works sometimes not and I have no way of seeing an overview to debug
Re: Why is bridging not being applied?
Can you attach the factory file (File > Save Factory File As)?
Image_Engine
S3D-Jason wrote: ↑Thu Jul 27, 2023 11:55 am Can you attach the factory file (File > Save Factory File As)?
This is a client job and is under NDA
Can I send the example to secure/private destination please
Image_Engine
Image_Engine
Hi, I have not received a reply to this
I run a business... and paid for s3d including the recent upgrade and I really need support here...I have paid jobs depending on it.
Please reply
This is a community forum, so if you can't find a way to post an example file it's going to be hard for others to help you.
Judging from your picture, you may also want to try adding 1 bottom solid layer, since bridging generally only happens when you tell the software you need a solid structure at the bottom (otherwise it leaves it open).
Image_Engine
S3D-Jason wrote: ↑Tue Aug 01, 2023 9:39 am This is a community forum, so if you can't find a way to post an example file it's going to be hard for others to help you.
Sorry I had thought trouble shooting etc was vendor based or at least supported.
Thanks again
Bye
Image_Engine
I would still want bridging to be applied regardless of bottom skin condition...
Thanks again
Bye
