lforbes
Support for Bambu P1S
Hi
I see the support for P1P and X1C for the Bambu.
I am wondering if anyone has the updated settings to support the P1S that just got released? Would it be the same as the P1P?
That is the one I have ordered and I love Simplify3D 5.11 and definitely do not want to go back.
I currently have an AnyCubic Chiron and an AnyCubic Photon M3 (resin not supported) but am excited to use the P1S for faster printing.
Re: Support for Bambu P1S
The printer was only released a few days ago, so we're still gathering more information. However, the only main changes the manufacturer lists vs the P1P that we already support is a prefabricated plastic enclosure, improved fan control, carbon filter, different cable chain, and the ability to print higher temp materials. Those are relatively minor changes and none of them sound like they would largely impact the slicer settings that are required to operate the machine.
Short answer - we have every reason to think the P1S will be supported since the changes are incredibly minor compared to the P1P that we already support.
lforbes
Thank You.
Simplify3D profile works great for P1P. I have been testing it. The print speed in the S3D is slower than the Bambu Software so the print takes longer. However, the Bambu Software doesn't have the advanced process nor the ability to do a 10 layer skirt for bed adhesion.
Simplify Default Speed 7500 mm/Min
Bambu P1S 200 mm/SEC Outer 300mm/SEC = 12000 - 18000 mm/Min
Simplify Travel = 18,000 mm/Min
Bambu Travel = 30,000 mm/Min
Did you mean to say P1S or P1P? I got the impression from your last post you were planning to test on the P1S instead of the P1P.
PS - you can easily increase the speeds in S3D by going to Edit Process Settings > Speeds tab, and increasing the "Default Printing Speed" or "XY Travel Speed".
CygnusProjects
When will the Bambu Lab P1S be supported officially? Or are their no plans to do so?
We have already developed a profile specifically for the P1S. As mentioned above, it is very similar to the P1P so there are very few changes actually needed.
If you need the profile, please feel free to contact our team directly at the link below:
