Hi All, I`m running a two headed/extruder Raise 3D pro. I want to run the prog through the RH extruder however when I do the printer stops and reports an error from the `filament manager` (as if theres no filament - but there is!!!!!!!).
On the main screen I have annotated `RH extruder only` and on every other screen tab where it says LH Ex I have changed it to RH.
But no joy! So I`m doing something wrong and basic (coz I`m a newbie).
Also I`m let to beleive that the LH extruder `should` automatically raise up so it doesn`t interfer with the RH extruder (that makes sense) but it ain`t.
If someone could help I`d be so pleased!
TIA
