I've been waiting at each update for this to function. Can't read the files on the card nor send them to be printed over USB. It is communicating with the printer, but doesn't see the card.
I may be misunderstanding this....you're saying simplify can't see the SD card when it's in the printer?
I think that's normal? Simplify should be able to see the card if windows explorer can see it but it would need to be plugged into the computer directly for that.
I've never had an issue doing it that way.
If you have communication it should be able to send via USB unless something is misconfigured but the files would need to be on ur computer for that.
Can you trigger movement and heating through simplify?
Have you tried manually sending gcode commands through machine control panel?
Does communications tab show any errors while trying to send?
Those would be the first things I checked....then maybe your staring scripts or profile settings.
Sorry if I misunderstood the question.
