knutselsmurf
REPRAP issues, object loading
I have a BLV printer with DUET (Reprap firmware), latest Simplify3D software.
Most importent problem: when I start a print the position of the printerhead is not correct, it's almost outside the printerbed!
When I load an STL-file (size=200x200) for my Ultimaker3, I can print it: no issues.
When I select the BLV printer (which has a bigger bed: 345x350), this is not shown in the Simplify3D software: the bed is not resized (you expect that), ofcourse using the same STL file.
Seems to be the software needs some improvements..
Re: REPRAP issues, object loading
Are you sure you setup the build correctly? Try deleting ALL of the processes in the list on the left, then add only 1 process, and use the Select Profile drop down to select the machine you are using. At that point, the 3D view and the preview should match the printer correctly.
