VitHudecek wrote: ↑Sat Dec 09, 2023 6:57 am
It doesnt matter what layers are above
It does. And it's not hard to understand.
What IS hard to understand is you mixing up "should make full layers", marking internal overhangs on continuous extrusions in
red but then claiming to talk about start/finish points of extrusions.
Then you claim the "Extending Sparse Infill" is exactly what you want - just to call for solid layers again.
This is why following layers ARE important to judge the current layer:
Note the indent on the left object.
The area under the indent is lower, therefore solid infill has to start earlier to stay within the configured amount
of solid top layers.
And asking for a feature like "Extending Sparse Infill" is different from "should make full layer". Because if that was done
above example would end up with 6 top layers around the indent instead of the configured 5.
Maybe you should try to tell what it actually is you are looking for.
- Extending the first layer of solid infill on sparse infill
- Automatically adjusting the infill structure to provide better support
- Add full solid layers whenever a part of a solid infill starts, no matter the size of it
All of this would help in these cases - still it's three VERY different approaches.
This category is called "Troubleshooting and Bug Reports". What you're referring to doesn't look like a bug - it's behavior
most slicers offered for many, many years - with PS2.6 introducing a possible improvement. And that version (not beta/alpha)
hasn't been available for even 6 months yet.
Up until then it's always been part of the slicing to check for proper internal supports. Because if you don't provide infill
settings for sufficient internal support you end up with massive internal overhangs. No matter if PS, Cura, S3D...
Troubleshooting:
Adjust your infill while slicing to properly support the top structures of your object, avoid massive internal overhangs
Bug:
I don't see a bug here
Feature Request:
Wrong category
