SocratesTrains
Tried to use migration, processes not transferred
I just tried to use the migration assistant, figured I'd make a copy of my settings - but now they are all gone! Please help me recover all my processes!!!
This is the 2nd time I've lost all my processes!!! Very unhappy!!! Please help me find them.... TYI
Re: Tried to use migration, processes not transferred
Are you referring to processes or profiles? When you run the Migration Assistant, it should already bring over your profiles. You can see them by going to Edit Process Settings and expanding the "Select Profile" drop down list.
If you have specific processes that you want to transfer from V4, you can always just export a factory file that includes those processes and then open them in V5. However, you definitely don't want to store your important printer settings as just a bunch of processes. The processes are meant to be temporary settings that are configured for each print. For example, things like the variable settings wizard or dual extrusion will reconfigure or create new processes. If you want to save your printer settings permanently, save them to the intended profile database by double-clicking on the process and choosing "Save As New".
