Marcodd750
problem with k1 max
Good morning, I use simplify 4.1.2 and I got a Creality K1 Max.....what should I put in the start gcode and end gcode? I can't get it to work with simplify
Re: problem with k1 max
The K1 Max is only compatible with the new V5 software. There have been many software changes in the past few years that were required to support the latest generation of printers, so many newer machines don't work with the older V4 software.
Once you upgrade to V5, you can download the K1 Max profile by going to Help > Configuration Assistant.
