nerfherder0000
Supports make my model hover
I'm brand now to S3D and racking my brain. When I add supports to my model, it makes my model hover 10 layers high and therefore won't adhere to the bed. The problem doesn't show up until I slice it, then I see it in the preview. The 3d printer is unable to print it correctly.
Re: Supports make my model hover
It's hard to tell, but is your model getting really thin at the bottom? If so, that part of the model might be disappearing due to your thin wall settings, not the supports.
Can you post the factory file?
nerfherder0000
It does get really thin at the bottom. Here is my factory file.
Cutter_2.0_(2).factory
(58.23 KiB) Downloaded 218 times
Last edited by nerfherder0000 on Mon Jan 08, 2024 11:30 am, edited 1 time in total.
If I remove all the supports, those tiny thin parts of the model still don't show up, so it has nothing to do with the supports themselves. Definitely just a thin wall issue.
To learn more about printing thin features like this, I would strongly recommend reading this article:
https://www.simplify3d.com/resources/ar ... -features/
