Good afternoon,
I went to a .8 mm nozzle and quickly realized I needed to adjust my speeds to no overrun my hotend which can only do about 15 mm3/s.
I was delighted to see the feature "Reduce print speed for excessively high flow rates" and set it for 13 mm3/s.
However it didn't seem to do anything. I was still getting 100mm/s speeds which with .8mm nozzle by .3mm layer is 24mm3/s .
I'm not sure if it didn't work at all anywhere, or just didn't work for some features like brim? On the 2nd layer of brim it was running 100mm/s when it should have throttled down to like 55mm/s . I searched through the gcode and saw lots of 100mm/s speeds so its not just the brim that it was doing it on.
Thanks,
Jeremy
