borgis1
Alternating direction of extruder
Is there a way or can you add an option to turn on a way to alternate the direction of a print?
For the record: no, not inside outside stuff.
I use a robot to weld and a weld should never start and stop in the same spots.
If I weld something with a closed shell it does not matter with a random start point
If I weld a single line on top of each other, or a line starts / end at the same point at the end of a single wall, that wall will start to deform at just about layer 2...
