I'm printing with flexible filament and need the walls of my part to be as thin as possible (essentially the width of the nozzle - 0.4mm in my case).
Single extrusion walls have caused me grief for way too long. I either get less than acceptable surfaces when printing, or completely absent sections here and there after slicing. Most of the "missing sections" go away if I merge my model in Fusion 360, so that's a step in the right direction.
If I select "Allow Single Extrusions" in the Advanced Settings under External and Internal Thin Wall Type, the preview of the sliced part results in a nice smooth curve in dark blue - indicating a single extrusion. However, when printing, the wall is a series of very small and jerky segments that leave a very rough surface.
If I leave that setting on "Perimeters Only" the curve prints smoothly and leaves a perfect outer surface. However, the walls are actually two passes of the nozzle and my print has stiffer/thicker walls than I'd like.
How do I smooth out the curve when printing Single Extrusions?
In the sliced preview the differences are easy to see.
- The Allow Single Extrusions curve - when viewed line by line - is a series of very short extrusions with stops in between.
- With the setting on Perimeters Only the curve is still a series of short lines, but they are slightly longer and the stops in between are gone.
I have fiddled with the thickness of walls when modeling. I have experimented with the Extrusion width in Automatic and Manual mode. Nothing seems to fix the problem, so any help would be greatly appreciated.
Thank you.
