I am unable to get the support material to adhere to the model material using Simplify3D. It works with CloudPrint so it's not a material issue.
It seems to be either moving too fast or not extruding fast enough. Even in the Ooze Shield it has trouble.
In the profile settings, I have tried adjusting:
1. Extruder 2 Settings > General > Extrusion Multiplier
This setting seems to be tied to the same field in Extruder 1 and does not stay changed when exiting.
2. Support > Dense Supports > All
I can't find any setting here that help.
3. Speeds > General > Sparse Support and Dense Support Speed.
They do slow the extruder down, but not enough.
I attached a simple test part that I have been using for quick testing. Please suggest any changes to try.
