lurobamx
Design of experiments, new feature request
Hi
I am looking for the best setting for my CR-10 S5 with a direct extruder.
This took me to perform tests keeping some parameters fix while changing one at a time (experiments) to get the right setting.
Simplify3D has the process wizard, but it the modification and naming of the individual process are manual.
The feature request is an automated design of experiments:
The user defines the parameters to consider, such as nozzle temperature, extrusión temperature, speed, etc.
The user sets the test values for each parameter individually.
The software determines the total combinations to test
The user decides the experiments to print
The user imports the model, and aligns as desired
The software copies, accommodates the models , and assignes the process defined.
The rest of the process to get the GCode done is already known.
Mitchell_VonB
Re: Design of experiments, new feature request
This feature would be incredibly useful. I've had to set up test grids many times to determine the best parameters for two settings. Orca does have this under calibration for sever features (there is a retraction one for you to use right now), but the ability to do this in the way you describe would be a massive time saver and advantage for properly setting up these tests.
