nerys
Why is it filling the model? should be hollow!
One of the settings must be triggering the slicer to fill the model but I can't figure it out. infill is 0 solid is 0 no top or bottom layers. just 2 perms. (same problem with 1 perm)
Ideas? factory file attached
Falcon_Heavy_Earring(2).factory
(411.25 KiB) Downloaded 563 times
S3D-Taylor
Re: Why is it filling the model? should be hollow!
Reducing the value for Solid Infill Threshold Area should solve the problem. This is usually used to strengthen weaker regions.
