Hello, dear S3D-Community
I´m using Simplify3d for many years now and every now and then, I run into a specific problem: There are some parts which lead to slicing errors. The problem is that sometimes random infill layers are missing, while every other feature type on the same layer is perfectly fine. It looks like this:
The strange thing is that this error moves: When I move the part vertically (Z+-), when I rotate it or sometimes even when I just move it horizontally, the error disappears on one layer and reappiers on a different layer. It even occured that I printed the same stl-file 10 times in one run, where 9 parts were sliced flawless, but 1 part had this slicing defect. It makes obsolutely no sense to me how this can happen. If the STL would be damaged, than rotating or horizontally moving it shouldn´t have any effect.
The stl-file doesn´t seem to have any defects. There are no non-manyfold edges or self intersections detected.
I also tried different slicers, were this error doesn´t happen with the same files.
The factory file is attached here:
The defect appears on layer 1014.
Could someone try the factory file and check if the error can be recreated? Maybe it has something to do with my system, but if it can be reproduced, it might be a bug.
