jrhusney
[SOLVED] Can't disable raft for a single part
Hi! I'm performing a multiprocess, multipart print using v5.1.2
I have two parts "spout" and "clip". I have two processes "PLA-RAFT" and "PLA". PLA-RAFT has a raft enabled. PLA does not. I use Edit Process Settings->Select Models to apply each process to each part. Click on each Process from the Process menu verifies that I have one part applied to one process. When I click Prepare to Print and select the PLA-RAFT and PLA processes, both parts are sliced to include rafts.
I think this may be a bug! Is this a bug?
I'd be happy to record and share a screen recording, if helpful.
Re: Can't disable raft for a single part
If the parts are too close together they will have to share the same raft. Try separating the parts further on the bed and see if that allows you to turn off the raft for one of them.
If that still doesn't work, maybe you can attach a factory file showing the issue.
jrhusney
Thank you, I'll give that a try!
jrhusney
Just following up here, this was indeed the case. After nudging the parts apart a bit more, I was able to print 1 part with a raft and the other without. Apologies for the false report!
