nerys
Is there any way to intentionally connect my skirt with my models first perimeter?
So pet g can be a little tricky to get that first layer to properly stick I use lots of different tricks to make that happen The biggest help and of course is vision minor nanopolymer That stuff is dark voodoo some black magic witchcraft right there
I noticed something that happens every now and then if I print a tight skirt sometimes it'll ooze a little bit when it switches from the skirt to the first perimeter of the model and that little bit of ooze basically draws a line and that line pretty much guarantees that the print is going to stick.
Is there any way to do this on purpose? Draw the skirt and instead of stopping retracting traveling to the start point of the model and then pushing again instead just keep printing like actually print a line from the skirt to the model with no retractions or pauses as if it's just more of the model
Is there any way to do this intentionally?
It would dramatically improved the success of printing petty first layers I already set my first perimeters to be essentially vase mode I put little cuts in the model to connect all the openings in the first layer so it's one continuous extrusion The only questionable part is that very first push after it's done printing the skirt if I could connect the skirt to the model that were eliminate that and dramatically improve my walk away success.
