blobabee
Re: Creality K1 WiFi
I just realized that port 4408 is not going to work for most people. Without rooting the K1, the port simply denies the connection. Hopefully Simplify can work with Creality to overcome this?
ampster
blobabee wrote: ↑Thu Jun 22, 2023 1:42 pm Without rooting the K1
Not sure of details because I haven't tried but sounds very similar to Bambu Labs printers.
OneZ I3
CR-10S "Trailer Maker"
CR-10S "Black Betty"
Ender 5 Pro "Ginger"
Ender 5 Plus "Wilson"
P1P "Pooper"
K1 Max "Max"
blobabee
Ahh, gotcha. Well, definitely works once rooted. I've tested it as mentioned originally, so at least until something is worked out between S3D and Creality, I have Machine Control access.
MaciekSA
Hello,
Any further updates on this?
jamesn1960
Hello Jason,
Any further updates on this? And PLEASE Include the Creality K1 MAX
pbeery
Hi guys,
I can't get your Creality K1 solution working. I'm using the port 4408 as prescribed. and the IP address I get from the Creality Print software.
Attempting connection at 192.168.68.75:4408...
Connection failed.
Connection timeout. Make sure the device is turned on and the connection details are correct.
SENT: POST http://192.168.68.75:4408/command {"GETPRINTERSTATUS": ""}
SENT: GET http://192.168.68.75:4408/api/v1/system
SENT: GET http://192.168.68.75:4408/login/
Connection failed.
Attempting connection at ws://192.168.68.75:4408/websocket...
Fruitcake2020
Please get WiFi working between the K1 Max and Simplify 3D. 4048 is not working and I do not have a clue what "rooted" means for the ip address.
Tossupper
Hello!
Any further updates on this? Port 4048 is not working for me!
bryanclinko
Simplify3D DOES have a Creality K1 and K1 Max profile(s) now, but the wifi still isn't connecting. I am hoping to get back to the Simplify3D software as it has so much more than CrealityCloud.....
gracilsinfor
As of today I am not being able to connect S3D 5 to a Creality K1 (MAX), nor by WiFI or Ethernet, manually and whatsoever port I try. Is there a more proper way to circumvent this without having to root the printer? it is a brand new printer so I don't want to void manufacturer's warranty. Thanks
