BikeWazowski
Re: FLSun T1 Pro Fan Control not working
I'm about to start a print, but it looks like i was missing this line in my starting GCode:
M106 S[fan_speed_pwm] ; set fan speed
parallyze
BikeWazowski wrote: Fri Jul 11, 2025 2:55 pmSOLVED.
What's the difference in the gcode output then? The M106 commands had been there before, so how did adding another M106
to the start script change the behaviour? :? :o
BikeWazowski
I didn't look at the output since i didn't care as long as it worked, but ill look now lol
BikeWazowski
the layer line gcode is exactly the same "M106 SXX" so it must have been defining that variable in the start script?
and/or I also checked the "include thumbnail images" box in the output tab with thumbnail "encoding" for Klipper. not sure if that had any difference. either way its working now!
mojisuucount
BikeWazowski wrote: Fri Jul 11, 2025 10:26 am to meet the max char limit for posts, i deleted a bunch of random G1 code from the second half
無料の文字数
It sounds like the Klipper firmware may be interfering with the fan commands from Simplify3D. Checking the printer’s fan macros and comparing the generated G-code with the firmware settings could help identify the issue.
