lucillekincaid
Illegal G-code when trying to print
Hello,
I recently upgraded to Simplify3D v5, which finally allows me to print wirelessly to my Qidi X-Pro. My printer is roughly 6 feet from the router, and I'm using an Eero mesh network.
However, when I try to send a model directly over WiFi, I get an error on the printer's console:
Illegal gcode in line: xxxx, P_4, T_10470103!
On another attempt, the error was slightly different:
Illegal gcode in line xxxx, P_$, T10470000!
Interestingly, the same models print just fine when I save the G-code to a USB stick and print from there. I've already contacted Simplify3D support, but they haven't been able to reproduce the issue.
Has anyone run into something similar with the X-Pro and Simplify3D v5? I'd appreciate any suggestions on what might be causing this or how to fix it.
