See attached factory.
Process 2 has a temperature set to turn the right extruder off after layer 165. It doesn't honor though.
I tried putting it in process 1 instead. Same deal.
It isn't in the output gcode at all on any layer.
I'd just use one process but there is that outstanding issue of no purge walls. So I use a first process to print a dummy cube so that the extruder is primed for the 2nd process.
Anyway, this is a very common use case for me, where I want to use support material but i don't want to keep the heat on the support extruder for a number of hours after I don't need that extruder any more. It works to change the temperature on a layer other than 1 if only one process. Catch-22 there.
