Hello all!
New S3D user here coming from Repetier and Cura. I have been using Cura as a slicer to generate the GCode and import that with Repetier with great results! I like Cura but it appears to just give up in the middle of a print more than it should so I just use it as a slicer. I have been reading a lot about S3D and thought I would give it a go. I got it installed and started working towards my first print. I have confirmed that with Cura/Repetier that the printer prints really good, but with S3D it appears that not enough material is being extruded. I have imported a Gcode file from Cura and the print is as expected. I believe this is a filament extrusion multiplier or something (currently set to 1) but I am not sure about the 5D Firmware option either.
I am hoping that you can help me out. I appreciate the assistance in advance!
Mike
