This is happening on multiple models. All of the models are prepared well. They are manifold, they are only one shell, all the normals are facing the same way, no overlapping triangles, or holes.
The gcode will send the hot end in diagonal paths off of the print 1-2 inches into a print, or it will shift to one side without the hot end bumping anything. It leads me to believe that its the code thats causing the issue. Is there something i should be doing?
