I can't figure out if this is a hardware issue or software issue. My printer is constantly stopping anywhere from 1 to 10 minutes into a print. The timing varies each time and it stops at a different place each time so I don't think it's related to .stl model flaws that got written to gcode.
I have a Makerfarm i3 8" with Ramps and Marlin. I have a 60mm fan on my Ramps board and it's warm but not hot to the touch when the fault occurs. I've reseated my thermistors so I know they are not shorting and throwing a "min temp" error. My motors are not hot. Everything is in great shape.
When it happens, all of my target temps on my LCD get thrown to zero and everything just starts to cool down. If I go back to S3d, the gcode is still scrolling away if I have 'Verbose' checked. It says an error occurred and to issue an M999 to reset. That's all the info.
I can't determine where this malfunction is coming from. Has anyone had S3D cause a malfunction like this? I still suspect it's hardware but I'm just trying to eliminate potential causes and narrow it down.
