dklassen
Default process
Be able to set a default process or at least have S3D open with the last selected.
Thanks!
KeyboardWarrior
Re: Default process
The software usually saves the last slicing process settings. You can also save a Factory File (File-->Save Factory File As), and then just open that as needed.
dklassen
Re: Default process
What I mean is I have several processes loaded. When I start S3D it always loads one of the other processes in the list by default. Basically the first one I created. However, that's not the one I use all the time so I have to select the other one. Would be nice if it remembers the last process you used and defaults to that one.
Re: Default process
im on the mac version so im not sure how they others are but when i open s3d it opens with the same settings and model as when i shut it down. does yours not do that??
dklassen
Re: Default process
I'm on a Mac too. For example. In the process window on the left, I have three processes. One called Printerbot, one called Makergear M2 PLA and one called Makergear M2 ABS. It always defaults to Printerbot and I have to select my M2 profile each time I open it.
Re: Default process
oh i see, it defaults to the last process in the list. i guess i never noticed this since i almost always only have one process listed there
dklassen
Re: Default process
Yep, that's the problem and you can't reorder them so if you have several you have to choose every time you open the software. Not the end of the world but it would be really nice if it would remember your last selection or let you reorder.
My latest issue is I can't delete any of the processes. Next time you reopen the software they come back.
