dsegel
diaphragmLayerInterval?
Does anybody know what the diaphragmLayerInterval option in the GCode that S3D produces is for? I have to processes that are identical in settings except for layer height, but they have different values for diaphragmLayerInterval. One has 20, the other 57. I can't figure out what else might be different.
Re: diaphragmLayerInterval?
That should be the print solid infill layer every x layers. That is one of those features i never use. Yours should probably be turned off.
dsegel
Thanks, that was it. I do have the option turned off, which is why I didn't notice it was different (I was only looking at options that were turned on). S3D still lists every option in the GCode header even if it's turned off.
yes if i am not mistaken 1 means on and 0 means off.
