I have a replicator 2 running sailfish in which I always print from SD card.
I am trying to figure out the workflow on getting an x3g file to copy to my SD card. It seems that I need to use the GPX tool to get that x3g file created, but there isn't much documentation on how that works. Has anyone successfully done this and if so can you give an example of what was put into Creator's post processing command and if there needed to an ini file created, edited for GPX for this to work? This software looks great but I'm having a problem getting over this first hump.
Thanks,
Jason
