Hiya all,
I'm new to the 3D printing scene. I've done a lot of research and I realise there is tons more to out there to research.
I want to print various parts with the best quality finish as I can.
As far as I can understand is that the serious ion is based on the layer hight.
If so, and the Z axis is accurate to 2.5 micron then the only limitation would be the software?
I was wondering if I sliced a model into 50 micron layers would a printer that says in its spec 100 microns, be able to print with half the spec'd layer hight?
For the wanhao printers, can the nozzle be changed with a smaller one like 0.2mm?
Cheers everyone
Becky
