I'm trying to use it also for my k8400, the support structure is great, but the the print is like polystirole foam i think the flowrate ist to low. would be great if there is a import filter for the cura settings
I've just installed S3D and I'd be grateful for some tips (the Vertex is also my first 3D printer). I read on the Vertex forum about deleting the heated bed, but some other settings, namely XYZ parameters and 'Flip Build Table Axis' set for Y-axis don't look right compared to the Vertex Repetier-Host settings. Should I set to the same as Repetier or doesn't it matter - I did choose the Vertex 8400 as machine. I haven't got round to starting a print yet
Nice with a Vertex thread! I've just started printing and there is obviously need for a lot of tuning to get the optimal print. With the default settings for K8400 I get too thick walls so part within parts that should be moving gets stuck in each other. I have tested with lowering the flow and that helps but then I get an almost see-through top layer. Look forward to share experience here.
One immediate question: Velleman says nozzle size is 0.35mm but Simplify3D has that setting as 0.5mm. Is this correct?
