Sallen1215
Build strts when right extruder is at temp but left is not
I have a Powerspec 3d Pro and the files im printing it heats the right extruder to temperature and tries to begin the print but the left is not to temperature and clicks as it is trying o feed filament... it may be my settings in Simplify 3d can anyone help? here is the factory file
T4Arm.factory
(68.67 KiB) Downloaded 228 times
rsavell
Re: Build strts when right extruder is at temp but left is n
You may want to check that you are using the correct dual profile.
You are using the wrong profile. You are using the powerspec (right extruder) profile. This is for prints using the right extruder ONLY!
If you want to print with both nozzles, then you need to select the powerspec (both extruders) profile. This will correctly heat both nozzles before starting the print.
Sallen1215
Thank you so much, i didn't see that there were three profiles for the Powerspec pro. You guys and Gals rock!
