just a suggestion here. if you have the wipe feature on and your using vase mode it will cause strange slicing to happen. a cylinder for instance will have gaps placed in a spiral going up your model. this is not a big deal really since you dont need the wipe feature and it should be off anyway. vase mode however overrides some of the settings, like infill, when you slice to make the whole thing work so i would suggest that you include turing the wipe feature off automatically along with infill and the rest of the stuff.
Just discovered this problem, too. Thank you for posting the solution, which is to turn off the wipe setting. It fixed the problem and saved me a whole lot of head scratching.
Automatically disabling wipe in vase mode seems like an easy bug-fix for the next release, and will save a lot of user frustration!
