frankpirz
new S3D user looking for a map from Slic3r
I suspect there are a lot of folks like me who have been using Slic3r and are trying out S3D for the first time.
Is there a map, either way, between Slic3r and S3D for converting Slic3r.ini files to S3D.fff files?
While some things are obvious, there are enough differences that I'm sure I'm going to get a couple of settings wrong :-(
[would be really neat if S3D could at least read a .ini file...!]
Frank Pirz
Media Conversions
KeyboardWarrior
Re: new S3D user looking for a map from Slic3r
frankpirz wrote:I suspect there are a lot of folks like me who have been using Slic3r and are trying out S3D for the first time.
Frank Pirz
Media Conversions
Could you post your Slic3r ini file as an attachment?
frankpirz
slic3r .ini file attached
not a windows text file, you'll need something like gedit (unix style text editor)
to make it easy to read it in windows
this one set up for abs, .3mm layers, 20% infill, 2 peripheral, 3 top/bottom (solid) layers
as a text file it looks like:
# generated by Slic3r 1.1.7 on Fri Jan 2 20:31:19 2015
avoid_crossing_perimeters = 0
bed_size = 300,300
bed_temperature = 0
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 30
brim_width = 0
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 0
dont_support_bridges = 1
duplicate_distance = 6
end_gcode = G92 E0.0 (Make Sure E is set to 0)\nG1 E-3.0 F700.0 (Suck up plastic)\nM106 (Turn fan on full power)\nM104 S0 (Cool down the extruder)\nM140 S0 (Cool down the heated-build-platform)\nG91 (Use relative coordinates)\nG1 Z3.0 (Move up the nozzle a bit)\nG90 (Switch back to absolute coordinates)\n;(G4 S60 Wait for 60 seconds to let everything cool down a bit)\nG1 Y300 F10000.0 (Move to part removal position)\nM18 (Turn off steppers)\nM107 (Turn off the fan)
external_perimeter_speed = 75%
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width = 0
fan_always_on = 0
fan_below_layer_time = 30
filament_diameter = 2.8
fill_angle = 0
fill_density = 20%
fill_pattern = rectilinear
first_layer_acceleration = 0
first_layer_bed_temperature = 0
first_layer_extrusion_width = 200%
first_layer_height = 110%
first_layer_speed = 30%
first_layer_temperature = 0
g0 = 0
gap_fill_speed = 20
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 0
infill_speed = 100
interface_shells = 0
layer_gcode =
layer_height = 0.3
max_fan_speed = 100
min_fan_speed = 75
min_print_speed = 30
min_skirt_length = 0
notes = .3 layer, .20 infill, 0 degrees, 2P, 3L, .1 retract, modified gcode
nozzle_diameter = 0.4
only_retract_when_crossing_perimeters = 0
ooze_prevention = 0
output_filename_format = [input_filename_base].30.20.2P.3L.1r.gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeter_speed = 70
perimeters = 2
post_process = /Users/James/github/local/Slic3r/utils/post-processing/filament-weight.pl
print_center = 150,150
raft_layers = 0
resolution = 0
retract_before_travel = 2
retract_layer_change = 1
retract_length = 1
retract_length_toolchange = 3
retract_lift = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 45
seam_position = aligned
skirt_distance = 6
skirt_height = 1
skirts = 1
slowdown_below_layer_time = 30
small_perimeter_speed = 50
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 0
solid_infill_speed = 90
spiral_vase = 0
standby_temperature_delta = -5
start_gcode = G90 (Switch to absolute coordinates)\nG21 (Set units to millimeters)\n;(M104 S175 set extrd temp - no wait)\n;(M140 S70 set bed temp - no wait)\nM106 S200 (Turn on the fan to 200)\nG28 X Y Z (home the X and Y and Z axis)\nG1 Z2.0 F1000 (Move up a bit)\nG1 X-9.0 Y150.0 F10000 (Move off the edge of the glass)\nG1 Z0.0 F1000 (Move down and touch the glass to prevent oozing while heating)\n;(M116 Wait for bed and xtrd to heat up apparently does not work)\n;(M109 S195)\n;(M190 S70)\nG1 X-9.0 F10000 (Move to the dump position)\nG92 E0.0 (Make Sure E is set to 0)\nG1 E5.0 F39.0 (Extrude a bit to get everything going)\nG92 E0.0 (Make Sure E is set to 0)\nG1 E-0.1 F700.0 Reverse E for prevent dribbling\nG92 E0.0 (Make Sure E is set to 0)\nG1 X10.0 (Move back over the glass to cut off the extrusion)
support_material = 0
support_material_angle = 0
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_extruder = 1
support_material_interface_layers = 0
support_material_interface_spacing = 0
support_material_interface_speed = 100%
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 70
support_material_threshold = 0
temperature = 0
thin_walls = 1
threads = 5
toolchange_gcode =
top_infill_extrusion_width = 0
top_solid_infill_speed = 70
top_solid_layers = 3
travel_speed = 110
use_firmware_retraction = 0
use_relative_e_distances = 0
vibration_limit = 0
wipe = 0
z_offset = 0
Frank Pirz
abs.30.20.2P.3L.1r.ini
(4.32 KiB) Downloaded 147 times
