yes i agree. to add to this i think the setting values in a process should be the same. in other words some values want you to enter a layer # and others want a height in mm. we just need to pick one and stick with it. to set a multi process print i can go into the cross section tool and figure out at what height in mm i want a process to start and stop. once that is set we need to slice the model then use the sliders to find the layer that we want to make cooling and temp changes, go back, enter it and reslice. maybe the cross section tool could give measurements in mm and also give the layer. i realize to figure out the layer s3d needs to actually slice the model so im not sure exactly how this would be implemented but thats why the s3d team makes the big bucks i guess
perhaps dont use the layer at all. switch it all to mm then the cross section tool could be used to take all your measurements. the slider on the tool would need a little smoother action though and not jump 2-3-4 mm at a time.
