I thought the Chimera has one heat block, so both nozzles would be hot. Also, you could use retraction vertical lift if this is a common problem.JFettig wrote:For some baseline settings if you need them, I'm running 6mm retract at 50mm/s(ABS), 1mm lift, .1mm coast, 5mm wipe. Under advanced, I do a 8mm tool change retract at 30mm/s and it rarely drules.
The one thing I don't like is if using one nozzle, you should keep the other hot because if it bangs into something, its better to melt rather than loose steps!
